shine
evo78
12-15-2005, 06:54 AM
hi i got a problem can i don't use the tamiya compound but can i use the tamiya modelling wax to make it shine
gionc
12-15-2005, 07:06 AM
eh?
just try but if you've orange peel wax couldn't make too much: so rub & wax
:grinyes:
HittenSwitches
12-15-2005, 08:44 AM
Wouldn't it be better to just use the rubbing compound, make the model look the best it can, rather than just throwing on wax just to give it a shine?...i would say use the compound cause it will clean up the model alot :)...good luck, post some pics of your models, or a link to you in progress models if you have any posted that it...i'd love to see them :)
RallyRaider
12-15-2005, 11:14 PM
In my experience Tamiya wax is more to protect the surface and preserve the exising shine. Other waxes like Carnuba wax actualy act as a compound, remove small amounts of paint and bring out the shine.
So to answer your question, unless the surface is already shiny then Tamiya wax won't help much.
Lambo003
12-15-2005, 11:44 PM
RallyRaider's right. . .
Tamiya wax will do nothing to smooth out a paint job. If the suface is a lttile rough, follow through with a compound.
There's been a lot of debate here on AF about whether to wax a model or not. I guess it boils down to personal preference but, I find that waxing models deepens the color and leaves a nice even luster. It also provideds a little protection from AC glues and epoxies during final assembly.
Not saying you can dump a whole bunch of super glue on a model and have it wipe right off. However, if you do happen to slip up with glue, touch up paint and such, it's usually easier to clean from a waxed finish. In some cases wax will also prevent fogging" that is common with AC's.
evo78
12-27-2005, 02:52 AM
hi i got a problem i bought a clear coat and the three tamiya compound (coarse, fine, finish) but can anyone teach me how to use it step by step thks alot
gionc
12-27-2005, 03:04 AM
I mean there's not much to teach: just to wear out your fingers: those P-man thread should be helpful,
http://www.automotiveforums.com/vbulletin/showthread.php?s=&threadid=8931
the difference with 3 step tamy set is only that those are 3 :grinyes: so use that in sequence (coarse>fine>finish) then wax
I think you don't need words now: just put a little of compound on a soft cloth and rub in little circles
also have a check on italianhorses.net, alex is a master in car finishing: you must find out a lot of great tutorial
evo78
12-28-2005, 08:48 AM
other than this italianhorses.net website do you all have anyone who can teach me the three tamiya compound (coarse, fine, finish) thks
klutz_100
12-28-2005, 09:16 AM
Honestly there isn't a lot to teach :) - unless I'm missing something.
First rub with "coarse", then "fine: then "finish".
You can then finish off with wax - I love Maguire's auto wax
HTH
evo78
12-28-2005, 09:53 AM
how should i know when to stop using coarse, fine, finish
ales
12-28-2005, 10:26 AM
Just try it already
Gamerxz
12-28-2005, 10:33 AM
hmm if u wanna test and see what compound does... take a unpainted shell and rub compound on it... the surface will turn mirror like... SO i suggest compound all the wAY! :) :iceslolan
evo78
12-28-2005, 08:17 PM
ok so how do i know when i should stop using coarse and move it to fine thks
freakray
12-28-2005, 09:10 PM
Experiment.
Use the compounds and learn as you go, there is no 'written rule' when it comes to these things as when it comes to paint there are so many variables.
Try different things, learn what works for you and what doesn't.
klutz_100
12-28-2005, 10:40 PM
In the immortal words of Mr. Nike (no relation to Mr. Surfacer or Mr. Putty): "Just Do It!"
As Freakray points out, there is no "formula". Advice is only good up to a certain point, after that you just gotta start generating your own experience.
HINT 1: Try it, go through the stages and if you are not happy with the result, you can always do it over again until you are happy.
HINT 2: If you can see bare plastic again, you were rubbing too long and too hard;)
cyberkid
12-30-2005, 07:52 AM
huh? ur link connected me to : Automotive Forums .com Car Chat > Jeep > Cherokee > Dude!!
I think this is the thread you meant: http://www.automotiveforums.com/vbulletin/showthread.php?s=&threadid=89313
missed a 3 on the end of the thread id.. :loser:
speedphreak
12-31-2005, 09:00 AM
I think I am gonna give the Coarse, Fine, Finish compounds a go. Does it have to be Tamiya? Because I think 3M makes compounds just like this, and you can finish it with a Meguires cleaner wax...that stuff makes a wonderful shine by the way.
-Chris
This may sounds way to obvious but I'll type it anyway....Using compound is just like wetsanding? Yes, no?
supra86
12-31-2005, 10:55 PM
-Chris
first: you dont halft to use tamiya compound, I use poly PB-230 polish and GS27 but thats just me, any polishing compound works, although some are coarser than others, exparament, see what you like to use.
second: basicly yes.
