Shrill sound
rico46
12-14-2005, 12:34 PM
I have a 96 Eddie Bauer with the 4.0 V6. I was driving home today and was going up a hill when I let off the gas just a little and a very shrill sound came from the front of the car. It seemed to go away some as a accelerated again. I stopped at a gas station and reved the engine up in park and neutral and could not duplicate the sound. When I got back on the road it returned somewhat more so when I let off the gas pedal going 35-45 MPH. Any ideas of what this could be?
bruker
12-14-2005, 03:29 PM
Have you ever cleaned or replaced the IAC valve (idle air control valve)?
When it starts to go bad it will make a howling sound at idle and the engine won't idle very good.
rico46
12-14-2005, 04:17 PM
Thanks for the reply. I have not checked that, and I will do so tomorrow night. After driving it more today, it seems it happens the loudest at 2100 or 2200 rpm's and mostly while accelarating. It does have a sort of rough idle sometimes. But it does sound like it can be air passing through something. Can I clean it well enough, or do I just need to replace it?
bruker
12-14-2005, 05:59 PM
I tried cleaning mine a few times before I just decided to replace it. If I recall correctly it was $50-$60 at Autozone. It was also a piece of cake to replace.
bumpinkicker04
12-14-2005, 08:28 PM
Rockauto.com is alot cheaper than autozone. Give it a try.
gtmud
12-14-2005, 08:49 PM
The sound could be just a vacuum leak, this will give you a ruff idle, and if the leak is small it will sound"shrill". Check your vacuum lines for wear or holes worn in them.
rico46
12-16-2005, 11:19 AM
Thanks for all the advise. The sound has vanished. I was going to change the IAC out this weekend and look for leaky hoses but it might be hard to get motivated without the problem. I will most likely still check for any leaks, but I am going to hold off on the IAC unless the problem comes back. Again thanks for the help.
bumpinkicker04
12-19-2005, 08:20 PM
There is a service announcement on the dust covers on the front wheel bearings. The only time the noise is present is from 10-45mph when it is less than 50 degrees outside. Mine had the same symptoms and that turned out to be that.
