Wont Start
dpritcha
12-14-2005, 01:34 PM
Wont Start:like Out Of Gas,but Not.checked Gas,oil,battery,timing Belt,fuses,plug Wires.how Do I Check Injectors & Fuel Pump.could Gas Line Be Froze?it Got Down To30 Degreese For Low Temp.anyone?
superbluecivicsi
12-14-2005, 04:21 PM
i assume you checked the plug wire resistance and battery voltage.
any no start situation requires checking for fuel, spark, and power.
you can check for spark on the plugs. for fuel, check for the fuel pump priming. 12v test the injectors and buy or rent a pump fuel pressure gauge.
dpritcha
12-18-2005, 03:08 AM
THANKS SUPER... I'LL TRY THIS
berkeysi
12-18-2005, 07:13 PM
Check the wires running to your starter, mine came undone once and almost caused me to buy a new starter.
kicker1_solo
12-18-2005, 10:42 PM
that has absolutely nothing to do with his problem!
berkeysi
12-19-2005, 10:07 AM
Your cool.
Your cool.
kicker1_solo
12-19-2005, 08:31 PM
Your cool.
don't be a fag. you gave him bad advice and I was correcting it. :rolleyes:
74 G/A
12-22-2005, 09:47 AM
A new battery solved my no start problem.
