Electrical problems and dead Tach
Scotty67
12-13-2005, 01:42 PM
My '84 Rabbit Convertible's tach stopped working and along with that so did the turn signals, gas guage and water temp. I figure it must either be a problem with power to that half of the dash or a common ground.
Has anyone else had this happen, if so, what is a good starting point?
Thanks.
zagrot
12-14-2005, 09:54 AM
check the multiconnector plug on the back of the dash gauge and the fuses. try shaking the wire harness, if the gauges begin to work there is a bad connection somewhere. i'm fairly sure that the dash panel contains a 5 volt regulator, maybe that is not functioning.
