Block Check. Eh?
TKUERZINGE
12-13-2005, 12:42 AM
Hello Again. How Do You Check The Rod Bearings On A D16z6. It Looks Fine And Turns Over At The Crank Without Problems, But I Was Just Burned With Another D16z6. Same Thing, It Turned Over Well At The Crank But When I Got It Started, It Wasn't Pretty. Any Suggestions Welcomed. Thanks. Tk
civickiller
12-13-2005, 03:02 AM
take off oil pan and baffle and play with the rod. if it doesnt move then bearings good, if theres play then bearings bad
YZ125rider21
12-13-2005, 03:29 AM
also if there metal shaving in there save them and recycle them aluminum and metal is making top dollar right now....
TKUERZINGE
12-13-2005, 03:38 AM
Thanks Alot, I'll Give It A Try!
