AIR DRIED BEEF DOG FOOD
Replacing front speakers on a 93 accord ex
Jweible
12-11-2005, 10:37 PM
I cant get the speaker covers off. In my Haynes manual it says theres a screw right under the corner of it and there isnt. Anyone know how?
AccordCodger
12-12-2005, 06:36 PM
Yeah - Haynes says a lot of things that "just ain't so." I just about wrecked my glovebox trying to follow their instructions - GRRRR!
russiankid
12-12-2005, 09:55 PM
look around the cover, or right on the edges of the cover, there should be either 3 or 4 little holes, inside the holes there are screws
mpumas
12-13-2005, 01:06 AM
If you remove the door panel, you will see how to get the speakers grill and speakers out.
Jweible
12-16-2005, 12:41 AM
thats gonna be a bitch
mpumas
12-16-2005, 01:52 AM
Not really that hard. The hardest part is removing the inside door handle. Remove the screw and push the plastic forward then out. Disconnect the door lock wires and then the linkage. There is a screw hidden behind a plastic cover in the arm rest and a few other places and also a plastic stud that pushes in at the front of the panel. Around the bottom, there are pry studs that hold the panel to the frame. When everything is loose, lift the panel out and up. Then carefully disconnect all the electrical to the window switches, courtesy lights and door lock controller and then the speaker. One other thing needs to be removed first, it is the cover for the side mirror. It just prys out. I can remove a panel in 15 minutes.
