Whoz had a bad day??.... Oh thats ME
Streetwarriorz
12-09-2005, 11:19 AM
Come on guys need some help here.
Just been out in my GTO TT did a few good runs but now she's choking like she's on 4/5 cylinders.
Though.....
Not all then time, only when she's under load, when sat there she can rev right up but idles irratically.
Under load she just chokes from 2000rpm and up its not the afm connector I checked and the boost hose seems fine, maybe its fueling??
crazy torino
12-09-2005, 12:23 PM
how long have you had the car.
reason asking if you just got it some one might have been putting regular gas and you might be misfireing like you indicate but thats the best guess i got with out hearing it. plus i really don't know that much about these motors (still learning).
Streetwarriorz
12-09-2005, 01:01 PM
Nah, not that.
Always run it on 99+ octane and had the car for a while.
Its as if the arm butt connector isn't attached
Morphius289
12-09-2005, 03:46 PM
99+ octane? I'd say just go with regular 93 octane unless your car is heavily modified. The octane boosters do give you power, but I'm cool with just spending money for regular gas and nothing else.
Streetwarriorz
12-10-2005, 06:53 AM
99 octane is readily available here in the uk also the car is an import from Japan so designed to run on 100 octane
Morphius289
12-10-2005, 09:42 AM
Oh, gotcha. How much does it cost?
l_eclipse_l
12-10-2005, 10:23 AM
What do you have set up in respect to tuning?
Streetwarriorz
12-10-2005, 10:29 AM
99 octane costs like 92p per litre so relitively cheap. :grinyes:
In respect to tuning I have:
* Jamaz APEX 3" twin exit Cat back
* SSA 3" Stainless Downpipe and decat
* SSA High flow stainless manifolds (fitting tomorrow)
* SSA High flow stainless O2 pipe
* Walbro fuel pump
* Blitz turbo timer
* BPU
* Air filter
http://www.cardomain.com/ride/2197600
Morphius289
12-10-2005, 10:47 AM
Very nice. I love that silver color. And all of those chrome parts :grinyes:
Streetwarriorz
12-10-2005, 11:33 AM
Thanks :naughty:
Will have them available for sale soonone all the specs are sorted, then the cooler pipes in polished aluminium. Should be cheap too!!
Still stuck on the running prob though :crying:
Stealthee
12-10-2005, 11:35 AM
99 octane overseas is just like our 93 octane. They only use one number where we use 2 then divide them by two. We use something like RON+MON/2 or something like that.
Streetwarriorz
12-10-2005, 11:52 AM
HUH???????? Add the 2 together and half them???
Octane rating is a level
Morphius289
12-10-2005, 11:59 AM
Well, I definitely learned something new. Thanks for the info stealthee. :smokin:
Stealthee
12-10-2005, 12:25 PM
Our rating is an average of ron and mon ratings.;) Hence why its divided by two. Japan, Australia and lots of other countrys use only the higher of the two numbers but I cant recall which is which.
Streetwarriorz
12-10-2005, 01:05 PM
See now that makes more sense, :grinyes: :lol:
I think Japan uses a 100ron rating and as 99 has just been introduced here in the UK, and relitively cheaply, most of the street racing and moddified world are moving over to it.
It has actually been officially tested to give an extra 15bhp on a stock wrx in comparison to the 95ron petrol also available here, though all I can really notice is a smoother pickup and delivery no real performance gain just driveability :smile:
quackmandude
12-10-2005, 06:22 PM
well anyways back to the question, it could just something as small as plugs and wires.. i had just bought mine, it had 150k miles, eh. it would bog down alot when i punched it, wouldnet even go in second gear. but yea try that
Streetwarriorz
12-11-2005, 04:25 AM
I'm going to have a go at the car today so will get back to you with the results in a few hours :smile:
Igovert500
12-11-2005, 05:18 AM
Well I'd pressure test for boost leaks, then change the plugs, then wires, adn finally check the 02 sensors...in that order.
Streetwarriorz
12-11-2005, 06:59 AM
All done and dusted :smile:
And.............
It was none of the above!!! Checked the system for leaks, heavy deposites on the plugs, lead resistance etc and it turned out to be much simpler :uhoh:
I had recently - being the day before - removed the fuel pump relay and hard wired it to run a permenant 12v as appose to the usual stepped process from 8.8volts at idle to 11.9 at full chat
Seems it had overloaded the system so I replaced the relay, disconnected ythe battery for 5 mins started her up and she's fine!!
Igovert500
12-11-2005, 12:54 PM
glad to hear it
Streetwarriorz
12-11-2005, 01:20 PM
glad to hear it
Not as much as me mate!! :lol: :lol: :lol: :iceslolan
Gateway
12-11-2005, 04:45 PM
i just need to put in my .02
You said it's imported from japan so it's designed to run 100 octane. Not to bust your bubble or anything, but your engine is identical as ours. It's not "designed" to run at 100 octane, but it can handle the higher octane just fine.
Morphius289
12-11-2005, 10:08 PM
Supposedly their 100 octane is our 93 octane. At least I think that's what you're referring to.
xXxRocker5150
12-11-2005, 10:18 PM
lol I don't think gateway reads stealthee's posts... if I see that it's extra long and fun filled I'll skim through it :p
Gateway
12-11-2005, 10:26 PM
i read just fine. i understand the difference between their octane ratings and our octane ratings. I should have clarified myself instead of making the post short in order to explain myself, but i guess I'll just have to make longer posts in the future so there is no confusion.
Streetwarriorz
12-12-2005, 03:23 AM
Alright to clarrify for you, jap performance cars are designed and timed to run a higher octane level (they call 100octane) that until recently was not available here.
Its already been covered that you use a diferent octane scale to everyone else, point being that if I was to put "OUR 95octane" in it would subsiquently damage the engine irreperably which is bad!
