'95 PA - Climate Control No Readout...Blown?
andrew910
12-08-2005, 10:03 PM
My 95 PA automatically adjusts the climate control to defrost and will not respond to any adjustments on the actual climate control module.
I found a cheap replacement part and switched it out, and to my surprise the climate control worked for a couple of days until it went out again. Now its back on automatic defrost.
I switched out the old fuses with new ones, but other than that i've done nothing. Some help please? I'm freezing my butt off.
HotZ28
12-09-2005, 10:37 AM
Did you change the actuator behind the glove box and check the vacuum lines to the resivor under the hood?
