Security problem
penone
12-08-2005, 03:36 AM
I have a 94 Maro with a 3.4 L engine. I have the viper system which is as old as the car. Occasionally, the security light will come on on the dash. I cannot start my car for at least five minutes. It then goes out and I can start it. It's beginning to annoy me to death. Can someone help me figure out what the problem is? Thanks.
javier_elias
12-09-2005, 10:16 AM
I have the same problem, what was the solution?
javier
javier
CamarosRsweet94
12-10-2005, 12:53 PM
Is your viper system aftermarket? Cause your VATS is what is keeping the car from starting. There is a resistor in the key that the system checks to make sure it is the correct key, so it probably isn't working right.
MarineOne
12-13-2005, 09:01 AM
daledep
12-16-2005, 01:28 AM
First air(dry)Clean key and lock cylynder, try it. if that doesnt do it, either get a new key, or disable the pass key decoder, so it doesnt send that dont start signal...
lynchmobb
05-13-2006, 01:49 PM
First air(dry)Clean key and lock cylynder, try it. if that doesnt do it, either get a new key, or disable the pass key decoder, so it doesnt send that dont start signal... how do you disable the key decorder.
lynchmobb
05-15-2006, 01:38 PM
Go to likeabigdog.com/vats. You will have to get your key checked for the correct number. Then go to radioshack, buy a resistor or series of resistors, which ever is closest to your number. solder the resistor to some wire, then in your car, follow the steering column, look for a orange wire, strip the wire, youll find two small white wires. Hook up one side of the wire to the other. I had no problem, was done in five mintues, and my car was sitting out of comission for a week, now back on the road. It will save you time and alot of money. Good luck.
CamarosRsweet94
05-15-2006, 10:38 PM
Come on man, stop bringing up old threads...
