Pulling "quick clips"
bomber5
12-07-2005, 03:55 PM
I have a 2002 grand am and the drivers side headlight is burnt out and I need to replace it. The problem is the two black "quick clips" arent coming out. What do I use to pull them up so the headlight will pull out?? and do they pull hard or should they come out easy?
richtazz
12-07-2005, 04:17 PM
They require a good tug, especially if they've never been removed before. A little spray lube and a pair of pliers will help.
Ridenour
12-07-2005, 06:07 PM
Welcome to the forum. I've always found the trick was you need to tilt / push them TOWARD the engine, and then pull up. Should come out easily if you do that.
xeroinfinity
12-07-2005, 06:48 PM
Do watch out for those tabs. They are usually sharp with burrs, and will cut into your thumb/fingers. I usualy use a tool, pliers or screw driver, lik richtazz said.. just my 2cents
