ECU TEST connector location !!
luvdeea
12-06-2005, 05:41 AM
Hello. I can't find the second diagnostic connector (ECU TEST), which seems to be located under the hood. I have a '96 explorer, 4.0 v6. With the under dash OBDII i can't read all engine parameters :(. Anyone has found it? Thx
way2old
12-06-2005, 11:47 AM
What kind of scan tool are you using? If it is a generic OBDII scanner, it will only read about 15 to 20 parameters.
luvdeea
12-07-2005, 01:35 AM
I use AutoXray Ezy Scan C5000, it has FORD program and i also have the plug for secondary FORD ECU connector. But i can't find that. With the second plug i can read all engine and transmission parameters. i did this on an other truck. Thx
