High beams not working 95 Crown Vic
vmsmgr
12-05-2005, 05:51 PM
My high beams don't work on my 95 Crown Vic. I replaced the multifunction switch and checked all fuses. The bulbs are fine and work if I hotwire them. The high beam indicator also works. Could it be the LCM ? Thanks in advance...
BMFer1
12-05-2005, 06:38 PM
Do they work if you pull the switch back to the flash to pass position?
Is this a retired police car, and if so, have they ever worked?
vmsmgr
12-06-2005, 07:26 AM
They do not work with the flash to pass either. They were working about two weeks ago, and my wife came home saying the high beams stopped working.
BMFer1
12-06-2005, 10:15 PM
In that case, it could be the LCM, but check it out. Unfortunately, I have no wire diagrams @ home, but if I'm not mistaken, the hi beam output on the LCM should be the same color as that on the headlights.
Prempt
01-06-2006, 02:14 PM
I also am having problems with my high beams. I have a 96 CV PI. The bulbs are good. What do I need to do to get them to work. Also, my rear right brake light doesn't work and the bulb is good. Any ideas? Thanks in advance.
mouchie
05-06-2006, 04:09 PM
hi all i hope some 1 can help,97 crown vic not a old cop car,high beam stay on had to unplug lights,so not to k ill the battery, and wat is LCM :banghead: HELP
