93 camry door handles
vbcamry
12-04-2005, 10:47 AM
The door handles on my 93 camry le have started to crack and need to be replaced. I have purchased the handles from a dealer on e-bay. Any advice on the degree of difficulty for replacing these?
JoeDB
12-04-2005, 07:32 PM
I replaced the outside drivers side on mine with no problems.
majones
12-05-2005, 03:37 PM
I've replaced interior and outside door handles on my 94; both were striaght forward. The only tricky part I remember was getting the plastic trim piece off from around the interior door handle without breaking it. Other than that start by removing the interior door panel, the handles will then be accessible and are bolted on (probably 10 mm bolts or nuts) and have a few rods connected to them but are easily changed over to the new handle. Good luck post back if you run into problems.
