Popping Noise
97T-Bird-
12-01-2005, 08:02 PM
Alright my front right wheel is making a popping noise every time i turn sharply...i thought right a way ball joint...but i had a mechanic check that out and he said they were fine...im gonna have it taken in tuesday but just wondering what everyone else suggests it is
97Bird
12-03-2005, 01:42 PM
Wheel bearing?
alphalanos
12-03-2005, 01:44 PM
oops you dont have CV. yeah bearing, or somethings probably loose.
intrcptrbird
12-08-2005, 01:51 PM
I have the same problem. I can not find the source. I checked all the balljionts, bearings, connecting rod and everything and it just keeps getting worse. If you find out whats wrong please let me know I can use the info.
overl0rd
12-08-2005, 11:30 PM
I'd say either bad sway bar end links, quite possibly springs, or struts.
intrcptrbird
12-09-2005, 10:27 AM
how would I test the springs or struts for this? Although it even happens when Im sitting still and just turn the wheel. The one thing I havent checked yet is the bolts on the rack and pinion itself. And as of right now it is not showing the signs of bearings going out. The tires dont have any play in them.
overl0rd
12-10-2005, 10:07 PM
You can watch the spring while someone turns the wheel, if it looks like it binds in spots and snaps out of it, then it likely needs replaced. Another way is to have a listen with a mechanics stethoscope (or a screwdriver or simiar), listen at different points like the strut mounting studs and the spring itself, etc. This will help pinpoint exactly where the noise is coming from.
