1/24 wheel nuts and bolts
91p10nizmo
11-30-2005, 03:20 AM
Hi
Does anyone know if there is any 1/24 bolts and nuts for the wheel hubs? So you unscrew the nut and the can take the wheel off.
Thanks Nathan
Thanks Nathan
gionc
11-30-2005, 03:43 AM
AcuStion(if I remember right) done 1 set for the Enzo, also as spare
I found out some other stuff: srew/bolt for RC servos fastening on AP: screw 2mm diam, bolt 3mm wide
and someone post this link last days
http://galtran.com/ScaleNutsandBolts/scalehexnutsandbolts.htm
obviously last 2 are standars screw/bolts, the rest with your fantasy...
Decs0105
11-30-2005, 03:44 AM
Acu Stion made a set for the Ferrari Enzo, but it's quite expensive!
Here's the link click (http://www.mediamixhobby.com.sg/catalog/product_info.php?products_id=1318)
Digitor
11-30-2005, 04:31 AM
I am currently working on the Tamiya 1/24 Ferrari F40 and it has bolts that come out so you can take the wheels off. I don't know how many kits have that feature though and they don't have nuts.
gionc
11-30-2005, 05:13 AM
ok, I think tamiya pin (like on some group C or 1/20 f1) isn't exactly a full funcionally nut,
Time ago I found out a tutorial concerning elecronic ON/OFF switches bolts/nuts used for removable wheels: the smallest I found out are 7mm wide (bolt) and 4.5 mm diam (nut) shape is quetly ok but proportions should be good for 1/12 usage
racingminiatures
11-30-2005, 07:37 AM
Hi Nathan,
I stock some made by Seimetsuya. They cost $15.50 (a little less than the Acustion ones which I think are also discontinued). Send me an email at racingminiatures@shaw.ca or just come by the site for more info.
Regards,
Ron
Racing Miniatures
www.racingminiatures.com
Regards,
Ron
Racing Miniatures
360spider
11-30-2005, 08:59 AM
Ron, is the Semitsuiya set you are refering to for Enzo? Could you post a picture(s)? Thanks!
Decs0105
11-30-2005, 09:46 AM
No, it's designed to fit 1/24 cars. Here's the link with a pic click (http://www.racingminiatures.com/ProductDetail.asp?ProdID=529&nPrdImageID=&CatID=62)
gionc
11-30-2005, 09:52 AM
MMMMMMM I'm greedy: I want 1 for my montecarlo gr5
jdmaccordian
11-30-2005, 11:12 AM
I put RC wheels on my 1/12 Camaro. I found 2mm diameter nuts and bolts at a specialty Sears Hardware store. Cost: $1. They're fuctional and I plan to putty up the nuts and make it look like a spindle hub. I would check a place like this for some options before spending $15-50 online. Good luck.
racingminiatures
12-01-2005, 01:22 AM
Hi,
As mentioned above the set is generic for any 1/24 car. You could easily use this on the Enzo. Just plug the end of the nut and use some circular Ferrari decals from your parts box or from the Model Factory Hiro emblem set etc.
Regards,
Ron
Racing Miniatures
Regards,
Ron
Racing Miniatures
360spider
12-01-2005, 07:46 AM
thanks Ron.
1986Z28
12-02-2005, 06:19 PM
smallparts.com
