1897 B250 5.2 wont start
castor75
11-29-2005, 08:02 PM
starter works. coil works. no spark at plugs. must be distributor right? if i mark the rotor position and install the new distributor correct will i have to adjust timing? any other ideas on why it wont start? ill never buy an auction car again!!!
brattzzzzz
12-01-2005, 03:09 PM
i have a 94 ram van and i checked the coil and its good i swapped the distributor and it still did not work. i checked the wire from the coil to the distributor and it works. i changed my ignition and it still doesnt work
i was told i need to bypass the starter relay or module and just put 12volts on the coil and try to start it
im going to try that today but i still do not know why there is no power to the coil in the wires
when you turn the key on the dodge ram vans to the start position you should get a reading on the wires to the coil for power
if you dont theres a problem with the power and thats my problem but all my parts are good
good luck with changing your distributor i dont know if it will work
try hooking up 12volts to the coil to bypass the problem if you dont have the power when your van is in the start position
castor75
12-01-2005, 05:37 PM
Of course an 1897 van would have problems. That was supposed to be 1987. Simplest of things, it was spark plugs.
brattzzzzz
12-01-2005, 11:05 PM
ooh lucky you
i have no power to the coil
Solracthenotorious
01-06-2006, 11:35 PM
id check my ground ... if ure not getting 12v at the starter ......
