1997 Tahoe-hard To Start
ROGER CHAVEZ
11-29-2005, 11:19 AM
I Own A 1997 Tahoe 4x4 With A 5.7 Vortec Engine. It Has A K&n Cold Air Kit. Recently, It Starting Having A Problem. In The Morning,it Starts Fine And Runs Great. After Driving It For A Few Minutes, I Turn It Off And Park It. When I Try To Start It After 20 Minutes, I Have A Hard Time Starting It. I Have To Crank It At Least 3 Times Before It Starts Up. I Drive It Around With Absolutely No Problems. I Just Installed New Cap&rotor,coil,spark Plugs,coil And Fuel Pump. The Problem Is Still There.
Any Suggestions To What The Problem Could Be..............thanks
2000CAYukon
11-29-2005, 01:14 PM
Fuel Pressure Regulator. The diaphram leaks causing your engine to flood. Overnight is fine because the fuel evaporates.
//2000CAYukon
//2000CAYukon
ROGER CHAVEZ
11-30-2005, 09:08 AM
//2000CAYukon
THANKS FOR YOUR INPUT. WHERE IS THE PRESSSUE REGULATOR LOCATED. THANKS
//2000CAYukon
2000CAYukon
11-30-2005, 12:02 PM
Under the top half (plastic part) of the intake manifold.
//2000CAYukon
//2000CAYukon
