b20 vtec set up info
crabby760
11-29-2005, 01:23 AM
i got a b20 block and a b16a head comlpete motors also
what head studs do i need... i know arp but for wat motor?
getting the golden eagle complete ls vtec conversion kit... WILL IT WORK?
also wat arp rod bolts?
i know i need gsr timing belt and water pump...
Kuntry_Boi06
11-29-2005, 10:43 AM
researched? im sure somenone else has done this b-4. ya i would stick with arp. im not sure about which studs to go with might have to do some drilling and tapping. but dont take my word for it.
civickiller
11-29-2005, 01:08 PM
for the headstuds, you need b18c (gsr or itr) they are the right length
you can get the GE lsvtec kit but make sure you get a 84mm headgasket to match your bore
why not just get rod bolts for the b20?
