juss stopped running !!!!! please help
monchi954
11-28-2005, 05:57 PM
I was driving down I-95 bumper 2 bumper traffic as soon as a saw an exit for da turnpike I took it was like 90mph then rpm just stopped running
no weird noises, no smoke, engine not hot, none of that. idk what to do
Checked spark plugs, put gas, charged battery changed its connectors and cleaned corrosion
Still no results
car did not show any signs prior to that
da only thing i did notice before starting the trip the radio turned off then came right back on
i was told cannot be the alternator because the battery was still good
and also the starter gets to the engine the belts spin but is like the engine does not get a spark or gas 2 start
Any suggestions
Still no results
Any suggestions
AccordCodger
11-28-2005, 07:18 PM
What age? Mileage? Model (though that doesn't matter much)?
When was the timing belt changed last.
Well? Does it have a spark? Does it have gas? (You can smell that in the exhaust)
Way too little information here - we aren't clairvoyants.
monchi954
11-29-2005, 10:54 AM
true put little info
its a 94 accord
has about 130,000 miles
the timing belt has been changed before
and the spark plugs are not making any sparks
its a 94 accord
AccordCodger
11-29-2005, 09:14 PM
OK - maybe distributor/igniter
ProMan
11-30-2005, 06:13 PM
It's very possible your igniter. It's inside the distributor. Take off the cap and there should be a thin layer of powder deposit. Clean it up thoroughly and put the cap back to see if it works. If not, you need a new igniter.
