96 accord enigine prob
silverdragons101
11-27-2005, 03:26 PM
My 96 accord started kind of rough the other day and my check engine light came on. The car has trouble acclerating and the engine vibrates as i speed up. Any idea whats wrong with it? thanks.
civickiller
11-27-2005, 05:49 PM
whats the code?
silverdragons101
11-28-2005, 11:22 AM
the code said cylinders 1 and 2 misfire. looks like it might be the distributor.
silverdragons101
11-30-2005, 05:54 PM
well i replaced the plug wires and replaced the bad distributor cover (the disributor itself is ok) and it still wont run on all 4 cylinders. what else could be wrong? need help please.
mpumas
12-04-2005, 09:31 PM
I guess the distributor cover wasn't bad afterall if that didn't fix the problem. I would try replacing the sparkplugs and also make sure you have the spark plug wire sequence correct.
