HELP with installation of an aftermartket keyless entry system!!!
AbsoluteGTR
11-27-2005, 12:25 AM
HEY! Well the other day my friend and I were attempting to install an aftermarket keyless entry and car alarm system into my car...well we were halfway there! Heres what is wrong...we could get the car to unlock but not lock! Is there a general way that any car alarm/keyless entry system is installed? Do you connect the wires directly to the lock motor or just any wires running from it?
Thanks! Any sort or help or any tips would be GREAT! Thanks!!
AbsoluteGTR
11-27-2005, 12:03 PM
:feedback:
importaudihaus
11-27-2005, 12:44 PM
on the 97 eclipse?
importaudihaus
11-27-2005, 12:47 PM
you should let someone install it professionally. i have 2+ years of remote starts and keyless entry. there are many possible reasons its no unlocking. are you using a test light? does the lock need a resistor? does the car lock positive or negative? if it needs a relay, do you know how to wire it? what type of unit is it?
AbsoluteGTR
11-27-2005, 01:16 PM
Well its some knock-off brand I bought off of ebay...it actually has some nifty features and really isnt that of cheap quality, but still, my friend mentioned something about my car needing a relayfor teh unlock and lock part of teh install. can someone provide me with a wiring diagram of the eclipse?
Also around my area that want from $125 to $225 for an install..THATS BS to me!
Thanks anyways
Thanks anyways
AbsoluteGTR
11-27-2005, 03:28 PM
Does any one know where I can find teh wiring diagram? That would be alo of help! THANKS!
AbsoluteGTR
11-27-2005, 10:48 PM
:feedback:
importaudihaus
11-28-2005, 04:03 PM
i can get you something off directechs.com if i can remember the password
importaudihaus
11-28-2005, 04:11 PM
12volts white + ignition harness
Starter black/red + ignition harness
Ignition black/white + ignition harness
Power Lock brown/white - driver kick, door harness
Power Unlock brown - driver kick, door harness
Lock Motor blue/black 5wi driver kick, door harness
Unlock Motor blue/red 5wi driver kick, door harness
Parking Lights+ green/white + driver kick, harness to rear
Parking Lights- green/white - headlight switch
Door Trigger red/green - driver kick, harness to rear
Dome Supervision use door trigger wire
Factory Alarm Arm green/yellow - driver kick, door harness
Factory Alarm Disarm green/white - driver kick, door harness
Disarm No Unlock see factory alarm disarm
Horn Trigger green/black - horn switch
i in no way will be responsible for anything that happens if you use this. make sure you use a test light to make sure of everything
