95 lesabre Growel :disappoin
mrhawk1971
11-26-2005, 08:04 PM
i have a growling comeing from the engine area, i checked the power steering pump its full sould like a power steering pump thats about dry, but only slightly changed sound when wheels are turned, any idea of what it could be? or how to narrow it down seeings it has a surenptien belt :banghead:
kok328
11-26-2005, 09:05 PM
You need to replace your water pump. Remove the serpentine belt and rock the water pump pulley from side to side and rotate it a bit. Chances are you'll find the bearings have gone out.
HotZ28
11-27-2005, 04:40 PM
It could also be the power steering pump. Could the growl sound also be described as a moan?
mrhawk1971
11-28-2005, 08:23 PM
yes i could be described as a moan, but PS pump is full and appears to operate normaly, it also does not seem to change in sound when turning wheels and accelerateing. new pump is 25 bucks so i am going to replace it, cant hurt just hope it works.. :smokin:
imidazol97
11-28-2005, 08:45 PM
Have you had someone run the motor, turn the wheels to load the power steering pump, change the transmission through the gears, turn on the rear window defog and other electrical items to load the alternator while you listened around the motor?
Is it possibly an idle pulley?
Next step take off serpentine belt and test each pulley and item.
Is it safe to run the motor for a short time-seconds-without the serpentine belt on??? To see if it's in the motor and transmissions rather than an accessory?
HotZ28
11-28-2005, 09:01 PM
Where did you find a power steering pump for 25 bucks? All I have seen range from $65-115.00 remanufactured!
auto trainy
11-29-2005, 04:16 AM
It does sound like something I wouldn't have faith in.
Hey Z that car of yours is ausom did you buy it new or did you fix it to that status?
HotZ28
11-29-2005, 10:14 AM
Auto trainy, thanks for the compliment on the old "road hog". The PA was bought four years ago with 125K on it. It was a non-smoking one owner, clean Carfax and in immaculate condition. I use it for daily commutes (10 miles), to save my other cars, however it washed & vacuumed twice a week whether it needs it or not. (My friend owns the drive through car wash). It is a work in progress restoring to new condition, however, very dependable. Since I have owned it, I never had to drive my weekend cars in the rain! I guess you could call it my rain car!
:iceslolan
auto trainy
11-29-2005, 03:12 PM
:iceslolan
If that's your rain car ,what else are you saving?
mrhawk1971
11-30-2005, 08:21 PM
no the water pump is 25 bucks, i have no idea what the PS goes for, and have not had time to check all the suggestions but i do know that no matter how much draw i put on the alternator the sound does not change so i think i can rule out the ALT
mrhawk1971
12-31-2005, 07:33 PM
well ended up replacing the alternator, it had a little bit of a scrolling sound in the rear of it, checked water pump was tight and quite, but still had the noise, after test driving it with new alt, i felt all the pullys, it would appear the AC pump bearings have gone out, was very hot to the touch. anyone know if i can just replace the pump or has it contaminated the entire system?????
maxwedge
01-01-2006, 09:46 AM
could be the pulley bearing in the a/c compressor?
mrhawk1971
01-01-2006, 11:07 AM
could be but according to the parts store they dont sell the bearing alone, so have to get a new pump, but in order to get the warrenty with it i have to buy a condencer and drier and expantion valve, about $500.00 bucks all together.
