AIR DRIED BEEF DOG FOOD
1990 pontiac lemans le
jsyron
11-26-2005, 08:17 PM
where is the diagnostic port on a 1990 pontaic lemans le with 1.6 motor can not find under dash or hood help
rguishard
01-11-2006, 10:31 PM
If it is similar to the 1991 1.6 Lemans, it is located inside the car on the RHS -passenger side- kickboard. Their is a plastic cover that needs to be removed to access the port.
I used an Autoxray code reader but recieved an error codes that vacilated between "51 Prom Error" and vehicle not responding. When a pulled a sensor however the reader did correctly report a low reading for that sensor.
Hopefully you get good results.
