Something's Wrong with my RPM
98Lud
11-25-2005, 05:36 AM
well to start off ... i dont know what to do.. i had this problem before with my car ... but i cant remember how to fix it..
My RPM will stay at 1500 and wont go down.. when i drive it will go between 1500 n 2000 up and down... and in the morning its hard to start the car, i changed the oil .. because i was getting 3000K but that didnt help.
Does or Did have this kind of problem, if u know ...please let me know as soon as possible.
Lockdown_2001
11-25-2005, 03:29 PM
Ive been having a similar problem, the idle will b fine until i drive it, then whenever i push in the clutch it will bounce 1500-2000 until i warms up, then its fine.
98Lud
11-28-2005, 01:43 AM
No, i know that when its cold it would do that.. I've had that before.. but what I'm trying to say is, that it will never go down, It will always stay at 1500-2000 and I'm workin on it, but if you guys can help me with any clues or anything let me know. Thank You.
Lockdown_2001
11-28-2005, 06:48 PM
Maybe fool with the idle screw? Check and see if any vaccum hoses are pinched/Leaking, thats what i did but still nothing.
Mine goes away when its warm which baffles me, but urs sounds like its a leaking vaccum hose.
Lockdown_2001
12-04-2005, 06:30 PM
any luck?
98Lud
12-04-2005, 08:00 PM
I check everything out at a friends shop, and i took it to a computer scan, and the scan said that my COOLANT TEMPERATURE CIRCUIT is bad, but at the shop i lifted the car and my flex pipe on the exhaust is rippen apart, it still sounds normal but it is leaking bad, i dont know if that could be the problem, but maybe it is. I got the temperature circuit am i am workin on it now, but the engine is hot so i have to wait for it to cool down and for the coolant to cool down also. Does anybody think that the flex pipe could also be 1 of the reasons??????
Any idea if that could be the source??
Lockdown_2001
12-04-2005, 08:25 PM
Nah dude, I dont think thats your problem, but from the sound of it, id prolly replace it.
92_prelude_si
12-05-2005, 06:49 PM
I am having that same anoying problem with mine. I too checked for vaccum leaks, replaced my fast idle valve, messed with the throttle screw and its still bounces. When it does stay settled it stays at about 1200 RPM as well. I have run out of ideas.
Lockdown_2001
12-05-2005, 07:49 PM
Ive read the faq for this problem, theres a huge thread on it, but its not helping.....
I dont think it will cause damage but I dont like it regardless
joellthomas
12-29-2005, 06:21 PM
idle problem, common for honda, i guess everycar has this sooner or later, check idle thread below this
meelude
01-18-2006, 11:14 AM
ive got bouncy rpm too its very fustraiting in traffic ...mine only did it when cold now it does it all the time...previus owner ran it on standard unleaded:banghead: if u find the cure let me know!
Lockdown_2001
01-18-2006, 12:11 PM
I cleaned my EGR Valve and it helped, now it only does it 70% of the time. But its not gone completely, I suggest trying it out.
If anyone here can give me a writeup on cleaning my IACV then plz let me know, or just let me know if coolant is going to spray or leak everywhere so im aware when i do it.
Thanks
Thanks
olivernon
01-18-2006, 12:40 PM
I have a 1994 Si and the rpm started bouncing....continued till the car began to misfire and catalytiv converter got cherry red....a leak was found in the manifold and the washer replaced 1/10/06....that fixed the bouncing etc. Just driving in this morning 1/18/2006..it started missing and backfiring again, catalytic converter cherry red again.....whats going on, anyone else ever had this problem? Car is also overheating on standing still.
Lockdown_2001
01-18-2006, 12:48 PM
Anything coming out your tailpipe, like soot?
olivernon
01-18-2006, 02:03 PM
yes...a whole lot of soot exudes on each rev, it finally fell dead.
