Aftermarket Head Lights
MaaJa_Dah
11-24-2005, 01:52 PM
I was wondering where I can find some after market headlights for my 99 trans am. I've looked around and havnt found much. I really like these lights on this car
http://www.cardomain.com/ride/588838
But like I said, I do not know where I could find any. Thanks - Happy Thanksgiving.
Matt365
11-24-2005, 05:32 PM
those look custom.
Mr. Luos
11-24-2005, 07:07 PM
Those things are HIDEOUS.
I like my stock flip-ups. Kinda makes the car.
blindeyed
11-25-2005, 03:16 AM
If you wanna pay a $1,000 dollars go for it. That's a huge waste of money in my opinion.
http://www.breathlessperformance.com/products/253firebird.asp
driftinggrifter2
11-25-2005, 04:06 PM
I have to agree with Mr.Lous, There is alot of things you could do custom but certain things have to stay so the car keeps its charector
chiefsmackahoe
11-25-2005, 05:10 PM
:iagree:
:puke those look like shit, they just dont work with that body style
MaaJa_Dah
11-25-2005, 08:54 PM
Well my front left headlight just started acting up. When I turn on the lights, everything is fine; The head light go up and turn on. When I turn my lights off, they go down; But the left headlight motor continues to run after it is down all the way. I have looked the best I can to see if there is anything in the way. It is completely down! The motor runs (very loudly) for about 5 seconds before it shuts off. But whenever I use my keypad to lock or unlock the doors the lights go up and down and it makes the noise. I am assuming the reason the lights are going up and down is because the car gives power to the parking lights. And since the car thinks the lights are not down it trys to close them; Just like they close when you turn your parking lights off.
I was just looking for a solution to the headlight problem. It seems that the headlights on these cars are always having trouble.
brass_monkey93
11-25-2005, 11:12 PM
your headlight motor is out...which is a common problems on our cars. I suggest checking out ebay to find the brass gears which you put in the original motor..this will solve your problem. If you dont want to do this you can go to your local GM dealer and they can get you an OEM replacement. Good luck...either way you do it it will save you 100's of dollars over those custom headlights you showed us
Matt365
11-25-2005, 11:22 PM
:iagree: u beat me to it.
Matt365
11-25-2005, 11:23 PM
1 grand for 40 dollars worth of lights and a piece of plastic... no ty.
MaaJa_Dah
11-26-2005, 02:24 PM
Ok, I checked out e-bay. The only thing I found was this:
http://cgi.ebay.com/ebaymotors/1993-2003-FIREBIRD-TRANS-AM-HEADLIGHT-MOTOR-GEAR_W0QQitemZ8017278901QQcategoryZ6763QQrdZ1QQcmd ZViewItem
Is that the right one? You said brass, I dont want to buy a cheap plastic peice that will break if I really need something stronger.
driftinggrifter2
11-26-2005, 05:46 PM
[QUOTE=
Is that the right one? You said brass, I dont want to buy a cheap plastic peice that will break if I really need something stronger.[/QUOTE]
No thats not the brass gear that is pretty much the same gear thats in your motor already. Heres a link to site that has them.http://www.bfranker.badz28.com/headlightfix/#FreeGuide I checked EBay a few times and i havent found the brass ones there yet but this site has them for like $80 a piece :bananadie
driftinggrifter2
11-26-2005, 08:34 PM
theres also a section at the bottom of that site on how to fix your problem for 4th gen and 3rd gen birds. i know for a fact the 4th gen one works and others in here say the 3rd gen works also. the 4th gen way wont cost you any money just a little bit of your time.
