For Anniepooh30
AzTumbleweed
11-24-2005, 01:25 PM
Here's the way I would do it. First you have to remove the cover around the steering column. (Photo 1)
http://files.automotiveforums.com/gallery/watermark.php?file=/503/353032Escort1.jpg
There are four screws located on the underside of the cover. (photo2) Remove them. At this point only the lower half of the cover can be removed.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/353032Escort2.jpg
Now remove the four bolts that hold the steering column. (Photo3)
http://files.automotiveforums.com/gallery/watermark.php?file=/503/353032Escort3.jpg
At this point the steering column will drop down and you can remove the upper part of the steering colum cover. Now remove the three screws above the instrument cluster. Not sure but these may be Torx head screws. (Photo4)
http://files.automotiveforums.com/gallery/watermark.php?file=/503/353032Escort4.jpg
Now there are three more screws to remove on the underside of the plastic. (Photo5). You can then remove the dark colored plastic and repair the switch.
http://files.automotiveforums.com/gallery/watermark.php?file=/503/353032Escort5.jpg
AzTumbleweed
11-24-2005, 01:32 PM
P.S. In case you are wondering, that's a clock on my steering wheel. Good place for it! It's not to clear but it says it's time to eat turkey and then have a nap!
http://files.automotiveforums.com/gallery/watermark.php?file=/503/353032Copy_of_Escort5.jpg
zx2srdotnet
11-24-2005, 01:35 PM
why did you post this IN his thread?
anniepooh30
11-24-2005, 05:38 PM
I know exactly what you mean....I think I will go out this weekend and try to disassemble my dash this weekend. Thanks for the info...
