grinding noise when accelerating in firstgear
graphak
11-22-2005, 05:57 PM
I have a 96 Achieva, 4 cyl, 2.4L, fuel inject., automatic.
When I am accelerating from a stop, or very slow roll, I hear a grinding noise coming from the front of the car somewhere. It only does this when I punch the gas too hard, like when the transmission is under a higher load than normal driving. It seems to only do this in first gear, and it sounds like a manual transmission when someone grinds the gears.
I read in a GMC forum someone had the same problem and mentioned something about it being a problem with the tires, however it doesnt seem likely. Please help. thanks
G
62chevystepside
11-24-2005, 11:32 PM
try checking the transaxle oil it might be low, you might have a small leak in it. or it could be your cv axle.
HBKracker
05-13-2007, 02:15 PM
G
I am having this same exact problem... Neither of the suggestions are the issue for me. If you know what is causing this, please let me know.
There also seems to be oil leaking onto the engine, and it overheats extremely fast when sitting in traffic.
PLEASE, help if you can. This forum is great, I just registered, but it has helped me with a few problems over the last 3 years. Thanks for any info
BNaylor
05-14-2007, 10:18 AM
Welcome to AF.
Sorry but please check the date and do not resurrect old threads. I recommend starting a new thread/post addressing your issue. Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
