s-10 blazer fuel pump relay
BOBBYRJ
11-22-2005, 02:55 PM
My blazer is cranking but not starting. I think it is the fuel pump but want to check everything else befor i drop the tank. Where is the pump relay located on a 94 vortec s-10 blazer, (old body type)? Also is there anything else I should look for?
Thanks.
Thanks.
dmbrisket 51
11-22-2005, 11:32 PM
find the fuel pump test lead in the engin compartment and energize it, that will tell you if is the pump is workable or if it is the pump/wiring to it... relays rarly ever fail, although they do it isn't common, fuses are common though, check that too
