Rod Knock!!!!
TKUERZINGE
11-21-2005, 11:15 PM
Hey, It's Me Again. Finally Got My 1988 Dx Started, But It's Got A Terrible Rod Knock. Question/ Can I Change These Without Taking The Head Off, By Just Taking The Oil Pan Off? This May Be A Dumb Question, I'm Not Sure. But I Appreciate Al Input. Thanks. Tk.
YZ125rider21
11-21-2005, 11:27 PM
Well I would take the head off anywase probbaly bent a valve too if you still are driving it....
superbluecivicsi
11-21-2005, 11:30 PM
well, assuming there is no machine work to be done, you can do that. but your life will be miserable.
new rods, gasket, and macine work, your better off with swapping a used d15 with no problems.
TKUERZINGE
11-21-2005, 11:58 PM
Thanks For Getting Back With Me So Quick. I Am Not Currently Driving It, I Just Put This Block In The Car, The Guy I Bought It From Said It Was Fine, You Know How That Goes. Thanks Again.
civickiller
11-22-2005, 12:38 AM
on my ls motor you couldnt take the pistons out from the bottom, you had to pull them through the top because you gotta take the piston out to remove the wrist pin to change the rod. so you need to pull the head
ViewtifulCivic
11-22-2005, 02:20 PM
How can you tell it has a rod knock? Is it pretty loud or is it very faint? Is it deep or high? And is it very rapid and not continuous or is it steady and continuous? Just curious.
doug294
11-22-2005, 03:21 PM
Mine had rod knock and it sounded like someone hitting a piece of metal with a hammer in my car.
civickiller
11-22-2005, 03:22 PM
on my motor made more of a knocking sound as oppose to a clicking sound, it will get faster as the rpms increase. i heard mine over my open header so yeah. at first though it might just be a slight ticking and will get louder over time. it depends on what exactly happen to the rod bearings.
YZ125rider21
11-22-2005, 03:50 PM
fuck guys...get to the point if you rod is knocking just drain your oil...you will see all the CHRISTMAS GIFTS you ever wanted if thats the noise you hear...lol....I mean these presents come in big chunks...haha....so drain the oil and get back to us
civickiller
11-22-2005, 06:21 PM
yeah youll see big chunks of metal. my lower rod bearing came out in 3 pieces
1PhatCX
11-22-2005, 06:48 PM
not neccessarily
i drained mine, no chunks AT ALL, they were all in the oil pick-up
jeef
11-23-2005, 05:05 PM
If your rod is knocking there is a good chance you crank is shot or needs turned, and your rod is likely to be gone.
Hybrid1990crx
11-23-2005, 05:39 PM
yeah i'd pay money to see someone pull a piston and rod out past the crank...
best idea would to get a used block and swap it in. days worth of work tops even if you are slow.
91civichatch2571
11-23-2005, 06:17 PM
drain the oil, run a magnet through it a bit if you cant already see the fragments of oil floating around. you can change bearings by just dropping the oil pan, but like stated above... if you spun a bearing, theres like a 90 percent chance (at least) that your crank and/or rod are seriously damaged.
Hybrid1990crx
11-24-2005, 02:31 AM
if you spun a bearing, it would be retarded. There is no way there isnt tiny metal shavings that you cant see all over the place. and when you replace that one bearing, or even if you do all of them, all the shavings are gonna got stuck in the new bearings, causing hot spots, and its just gonna make a big mess.
So either pull the motor out and rebuild it, or get a new block.
doug294
11-24-2005, 10:57 AM
Mine started knocking for about 2 min then I heard a loud boom and black smoke everywhere. At that time I realized it was time to move on lol
TKUERZINGE
11-27-2005, 01:49 AM
Thanks Alot Everybody, I'm Just Going To Swap Out The Block, Seems Easier, Eh? Thanks Again.
