plymoth 01 Motor and trans swap for 03+srt4
SakuraNEON2001
11-18-2005, 02:40 AM
just trying to see if any 1 has any info. on swaping out the 2.0 automatic trans on a 2001 plymoth neon with the SRT-4 2.4 and 5 speed stickshift trans. weather it be what kind of parts i need for eather one or if they will fit in good thx :smokin:
das2123
11-18-2005, 07:56 AM
just trying to see if any 1 has any info. on swaping out the 2.0 automatic trans on a 2001 plymoth neon with the SRT-4 2.4 and 5 speed stickshift trans. weather it be what kind of parts i need for eather one or if they will fit in good thx :smokin:Yes it will fit and yes you can do it. The best thing you can do is buy the entire engine, wiring harness, transmission, and buy a stage one PCM. You can run into problems with the sentry from the stock ecu. Drop everything in with some modified engine mounts and a few other things and you are good to go.
das2123
11-18-2005, 08:13 AM
Here is a pic on an SRT-4 engine in a 2nd gen neon...
http://memimage.cardomain.net/member_images/2/web/1058000-1058999/1058226_17_full.jpg
