removing door panel
NateTheGreat
11-17-2005, 02:36 PM
Hi I have a 1998 grand prix se 4 door. I would like to know how to safely remove the door panel to install the new speakers I just bought without messing up the window/lock controls. If there is a thread on this specific topic a link would be greatly appreciated. Thanks!
Nate
BNaylor
11-17-2005, 02:46 PM
Try this one:
http://www.grandprix.net/upgrades/doorpanel.html
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
NateTheGreat
11-17-2005, 03:11 PM
ok thanks that helped a ton. New question..
the wires coming out of the door.. there is a red one and a gray one.. the gray is the negative and the red is the postive, correct?
BNaylor
11-17-2005, 03:37 PM
The documentation I have shows gray as the return line (-) and red (+) as signal for the driver door side speakers.
