AIR DRIED BEEF DOG FOOD
4.3 blazer, and when i gun it..
black wall st
11-16-2005, 02:13 PM
When i give my truck gas, it sounds like it's working alot harder then it has to be. Like when i am turning in an intersection in front of a car, you gun it to get out of the intersection, well my truck seems to make alot of noise but not move as fast as it sounds. Now i have heard people putting chain engine mounts on the sides of their engine bars to restrict the twisting the v6 does when under pressure, i am sure this is what is happening, any one else have this problem, and are there any fixes?
BlazerLT
11-16-2005, 02:21 PM
It could be also that your engine has to now turn 22s instead of the stock 15s.
This sucks power bigtime.
BlazerBoyLT98
11-16-2005, 03:11 PM
22's! I wouldn't expect your engine or tranny for that matter to last very long.
black wall st
11-16-2005, 09:48 PM
No, the car runs perfect, nothing is wrong any other time, and it's not like the car doesn't haul ass when it does make the sound i was just curious to see if anyone else tried to fix this problem or even had it. I run the 22's only last summer, for under 10 thousand miles. I'm saying like, it doesn't die, it just sounds like the engine is cranking or twisting and not getting the full power... No one else has this problem, i am sure that it is because of the high mileage, but i do drive like a saint, i try not to beat it up, now... Don't hate on the 22's, it's not like it is that must of a difference because a stock 15, and a 22. the weight difference in about 20 pounds. It's all good, just thought i would ask.
http://memimage.cardomain.net/member_images/6/web/2130000-2130999/2130370_163_full.jpg
I actually got better gas mileage with the 22's on the highway, go figure...
BlazerLT
11-16-2005, 09:55 PM
No hate for the 22s, just saying it will take more power to spin them.
Also, ever done a tuneup?
black wall st
11-17-2005, 06:39 PM
Suprisingly no, i just changed the plugs with 4+platinum blah bullshit, and i always rock the mobile 7500 syn. and i do the necessary requirements like the air filter, rotating tires, etc.
blazee
11-17-2005, 06:44 PM
The bosch plugs could be your problem, they suck ass in a vortec.
Ever change the fuel filter? Cap? Rotor? Wires?
BlazerLT
11-17-2005, 07:00 PM
The worst plugs in the world. Go with AC delco Platinum.
black wall st
11-17-2005, 08:13 PM
Ha, them bastards were like 6 bucks, but i have replaced fuel filter, and the whole unit for like 1700+ bucks... but i haven't replaced any of the other junk, i suppose it wouldn't hurt, that's my motto.
dmbrisket 51
11-17-2005, 09:22 PM
no, the worst is champion, then bosch, closly followed by nkg... as lt sugested, foot the bill and use what your moter NEEDS to run right, delco plat.'s
BlazerLT
Trust me, the plugs more than likely could be the issue.
dmbrisket 51
11-17-2005, 09:23 PM
btw, i run on 20's and never noticed a difference in sound or proformence
BlazerLT
11-17-2005, 11:06 PM
trust me, bigger wheels mean a heavier wheel to rotate.
It does hog a little performance.
Cailen
11-17-2005, 11:35 PM
I just thought I'd chip in and say those bosch 4s are complete and utter shite. The previous owner put em in 10k before he sold me my truck, and I drove another 5k on em before I couldn't drive anymore. Imagine a BIG honkin hunk of carbon stuck between one of those prongs and the electrode, and you have my #3 plug..
Night and day difference once I threw rapid fires in.
xjcamaro89
11-18-2005, 08:23 AM
If the engine sounds like it is running really hard and not going anywhere, any chance it could be the transmission slipping? If doing a tune up and makeing sure everything else is good first, but thats what it sounds like to me
riccbhard
11-18-2005, 05:11 PM
98 Blazer here; stock everything and when getting up to a around 2500 RPM the engine tends to get quite louder and a vibration can be felt in the floor. That; and the exaust seems to be getting louder over time. (It's rarely ran up to 2500; it usually shifts at a little under or over 2000 like normal.) The loud engine noise can be heard when going uphill when it downshifts and the RPMs go up.
Then again it does have over 111k miles
the only things that we've had to replace since having it has been a water pump, crankshaft seal, and alternator (which this 'new' alternator is already starting to go bad and it hasnt even been a year since replacement.)
Is it just me or do GM alternators not last very long?
BlazerLT
11-18-2005, 11:25 PM
Ever done a tuneup?
