67 250s (Any Mechanics?)
trazique
11-14-2005, 12:24 PM
Hi guys I have a 1967 250s that would not idle in gear. At first when the choke flaps opens after warm up it shuts off. so i went in to both carbs and cleaned them out. Now it idles but not when i put it in Drive of reverse it would cut off... Help.
mercedes420
11-14-2005, 05:38 PM
I'm not a mechanic, but first thing that comes to mind would be a fuel cut off switch.. I have a Mercedes Tech support number that I use religiously.. It is # 201-476-6200.. This is a number for the National Headquarters in North America.. I used to work at this building, and these tech guys know there stuff..
Best of luck...
Best of luck...
trazique
01-21-2006, 09:51 AM
I am restoring a 1967 250S I need to know if there is a web i can go to, to get unlimited parts down to a replacement screw. Help! thanks
mercedes420
02-27-2006, 09:14 PM
Performanceproducts.com should have everything that you could need... If they don't check out germanstarr.com
