Timing belt cover removel?
wakeboard_dude5
11-12-2005, 11:21 PM
Is it possible to remove the timing belt cover without taking off the crank pully? I need to replace the drivers side upper mount bracket to actually have my motor bolted in. The idiot who put the B18c1 into my EK before i bought it decided he didn't have to do the right thing and just drilling some new bolt hole's will do just fine. Well, the mount tore in have and the mount stud snapped in half (i'll post pics once i take some). The motor is still in the car and there is NO way i'll be able to take it out to put the bracket on. The third, and last, bolt i need to take off is behind that plastic cover and its the only thing keeping me away. If its not possable to remove it while leaving the crank on, is it too hard to take off? thanks for the help
apexin1civic
11-13-2005, 01:33 AM
you should be able to take the timing belt cover off of it ... im not sure how many bolts there are maybe about 5...all size 10...i took mine of my ls so my cam gears to show without takin the pulley off
