Wheel Offset
airFS
11-12-2005, 11:52 AM
I have a 96 talon and I'm looking at some wheels. While I was doing that I saw all different kind of offset sizes. What offset do I need?
AbsoluteGTR
11-12-2005, 01:11 PM
Offset is how much the rim sticks out from the center of the rim..I believe?!
For example if you have like a 2 inch lip, you might have a 38 mm offset.
Thats atleast what I thought it was, but what else would it mean the? LOL
97_3clipse
11-12-2005, 01:41 PM
keep it around 40mm and your good as song as you go no bigger than 8in wide.
drdisque
11-12-2005, 03:06 PM
offset is how far the lug face is from the center of the wheel in mm. Positive offsets mean the lug face is that many mm outside of the centerline.
AbsoluteGTR
11-12-2005, 03:38 PM
Thats what I said, right...Its pretty much the same thing!? :smile:
ted_ex
11-12-2005, 11:36 PM
It's where the wheel touches the rotor. Anything postive is outward, anything negative is inward. Basically the less the offset, the more the wheel will stick out from the brake. Most FWD or AWD cars use positive (like +30 +40) While RWD uses closer to 0 or even negative. Here's a site with some pictures and a better explaination.
http://www.yokohamatire.com/utcustom.asp
