AIR DRIED BEEF DOG FOOD
Transmission Change 1987 Chev 1 ton
~grimreaper~
11-12-2005, 12:06 PM
My tranny was changed from a manual to an auto, Now I am trying to get the reverse lights to work. Where is the switch located! Do I have to buy a switch or is there one in there already.
maxwedge
11-12-2005, 12:26 PM
Look for a switch on the trans or go to autozone.com/repairinfo fo a wiring diagram
broughy84
11-12-2005, 07:32 PM
What trans do you have? What year is the trans? Did you change the column too. 700r4's reverse/neutral saftey switch is on the column by the floor.
~grimreaper~
11-13-2005, 12:06 AM
I have a 1984 turbo 400 behind a 350, The truck used to have a diesel in it with a 4 speed manual trans. I am assuming the column was changed because it was a manual tranny before. All this was changed before I bought the truck. I have the wire for the reverse light traced back to the firewall I could just cut into it and run it to a switch in the cab but I would like to hook it up right.
mbumgua
11-15-2005, 10:03 AM
If you have traced the wire to the firewall on the outside , find it on the inside where it comes through. Trace it further to where there is a connection under the dash. unplug the connection and remove the wiring from the firewall and under the hood. The connection where you unplugged it should plug into the neutral/revese switch at the base of the steering column. If not then put female spade connectors on the wires to allow hookup. By the way-these two wires should be blue and green.
