Different sort of ABS question
the.dude
11-10-2005, 03:11 PM
I hate to even post on this since this board is already flooded with ABS TRAC questions. But I have been searching through past post and can't find anything reflecting on my problem.
I've got the ol ABS TRAC light going on, but it ONLY does it when I hit bumps. There is a set of railroad tracks on my way to work that set them off every day. I can drive for two hours on the interstate and not have them go off, but a good bump...on they go!
I just ran a scan and it shows several codes for the left rear speed sensor. One of them specifially said bad circuit. My question is....
Is this likely to be a wiring issue or do you all think it's time to buy another hub assembly?
Also, this hub was replaced about 2 years ago when a tow service strapped the wire and pulled it all out. I replaced the hub and repaired the wire when that happened. This makes me think that the wiring may be the problem.
MT-2500
11-10-2005, 04:15 PM
Look the wiring over real close where you repaired it.
It may have got moisture in the spot you repaired.
Or hook a volt meter before and after the repaired wire and wiggle the wire and spin the wheel.
Mt
Mt
richtazz
11-10-2005, 04:21 PM
Sounds like a wiring problem, but abs sensor problems can come and go.
BNaylor
11-10-2005, 07:19 PM
One thing you can do to the wheel sensor(s) is ohm it out with a multimeter and see if it's in a specified range of resistance. You undo the electrical connector and go across the 2 pins on the sensor/hub side.
Here are the specs:
Rear wheel sensor (1030 - 1180 ohms)
Front wheel sensor (1020 - 1137 ohms)
If outside of this range it's flaky. Also, maybe you can try to duplicate road conditions by using a rubber mallet and tap (not too hard) on the hub to see if it breaks continuity.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Here are the specs:
