97 camry dome light problem???
im_just_jaq
11-08-2005, 02:06 PM
my camrys dome light it out. the blue ring around the ignition is working. i checked the fuse under the trunk and it didnt help to replace it. is there another fuse box located inside the car? if so i couldnt find it. also my check engine light is on. are these connected? this is my first camry and i just got it a few days ago. its not the bulb or the fuse, so what are my options? the wiring?
AccordCodger
11-08-2005, 05:51 PM
No they are not. Get the code checked (Autozone will do it).
Are you sure it's not the bulb? Sure, it could be the wiring, but if the car hasn't been butchered by a do-it-yourselfer, that'd be a rare problem. Does is work with the switch on the light itself?
