alternator whine, belt squeal
larry@dons
11-08-2005, 10:20 AM
I was told this Rodeo had a bad water pump, but the problem is the alternator instead. As soon as you start it, the belt squeals, and smokes very badly. If I unplug the alt, it goes away. Seems like a short in the wiring harness, but I can't find any burned / hot wires. I've put 3 different alternators in this, and swapped the ecm, thinking it was demanding an overcharge for some reason. Anyone else run into this before?
Cat Fuzz
11-08-2005, 07:11 PM
Sounds like the belt needs to be tighter.
surferfletch
11-08-2005, 09:34 PM
That was my first thought, but in the course of putting three in you'd think it would have been tensioned properly once.
Canucklehead
11-08-2005, 09:42 PM
You'd think, but if the little tensioner bolt is missing or busted you may have trouble getting it tight enough.
Cat Fuzz
11-08-2005, 10:49 PM
The alternator belt has to be pretty tight or it will slip. Tighter than what most mechanics would consider good enough. I had the same slipping problem until I tightened the belt tighter than what I thought it should be.
surferfletch
11-08-2005, 11:03 PM
Same with mine. I'm constantly tightening that belt to eliminate the startup squeal.
larry@dons
11-09-2005, 08:09 AM
OK, I will try adding more tension to the belt. Does anyone know, is there a deflection spec for this, or just tighten it until it stops making the noise?
larry@dons
11-10-2005, 12:06 PM
OK, the belt is REALLY REALLY tight now, but it is nice and quiet, and the alt is charging well. Now it's so quiet, I can hear the timing belt idler rattling. Thank you all for your advice.
surferfletch
11-10-2005, 12:48 PM
Good deal. Shortly after (over?)tightening the steering pump belt once, I lost it. I guess it's overkill to keep a spare with you since there are 3 belts and a different way to adjust each.
Cat Fuzz
11-10-2005, 08:10 PM
Well, thats the tricky part. If you overtighten a belt, you run the risk of wearing out bearing and stuff. You might want to play with it a bit and get it as loose as possible without it squealing. A pain, I know, but it could save your alternator from having to be replaced.
