90 dynasty 3.3ltr stalling when engine is hot
holdemjunkie
11-06-2005, 03:03 PM
I have a 1990 chrysler dynasty 3.3ltr, it just started to stall on me. It seems to only stall when the engine is hot, I can re start it and drive it for a bit then stalls again. After a few repeats of this the car will not start at all, but engine cranks fine. After it cools down it starts fines and just repeats what I said above. I cheaked fuel presure and its fine its at about 43 psi and does not drop at all so that rules out fuel pump, changed fuel filter last month so thats not it. I'm thinking maybe coilpack?? but I'm not sure because usually when a coil goes it would't cause a intermitted problem it would just stop working and would't work again????
jeff compton
01-31-2006, 01:21 PM
sounds like a crank position sensor problem, pretty easy check when it won't start if you have a scanner, or do the ign key dance and look for codes, I think it's code 11 or 12, it's been awhile, get back to me if you want
jeff
