95 bonneville
Goodyear
11-05-2005, 01:18 PM
I found out they changed the mass air sensor,fixed the white wire to computer and changed cam sensor.Still doing same thing.Will stall at idle,check engine light comes on.Sometime will not start , :banghead: :banghead: sometime will run fine for a day ( MAYBE)
maxwedge
11-05-2005, 01:45 PM
The key to this is whether you have,spark, and injector pulse when it won't start, then the diagnosis can proceed from there. You can unplug the maf and it will start, it uses a default number to allow minimum operation. I don't know why those parts were replaced, same problem, if so take it back and ask them would they like to fix your car or refund your money for what didn't.
