91 LS OBD0 swap to 95 OBD1 civic
trazique
11-04-2005, 10:34 PM
Why does'nt my B18 in my 95 civic hatch start? I used the same harness in the civic... I crank the engine all 4 injectors sprays after the engine turns at least 3 to 4 times. if i sprayed starting fluid it woulsd start, then keep running but is i don't use any it would not start. HElP!!!
civickiller
11-04-2005, 10:48 PM
im assuming its converted to obd1 ?
trazique
11-04-2005, 11:02 PM
Im sorry did i make a mistake? maybe the 95 civic hatch dx is an ODB2. If not the car has never been converted. I bought it with the 1.5 engine in tact.
civickiller
11-05-2005, 12:08 AM
are you running a obd1 distributor? running a obd1 ecu ?
superbluecivicsi
11-05-2005, 01:29 AM
no power? or doesnt crank?
if it cranks, you checked spark? you say the injectors spray...........well how do you know this?
trazique
11-05-2005, 11:20 AM
I removed the fuel rail W/injectors attached still. and yes its also getting fire at the plugs.
civickiller
11-05-2005, 04:24 PM
injector wiring not in the right order
trazique
11-05-2005, 05:06 PM
What order should they be in all four are spraying at the same time...
civickiller
11-05-2005, 10:10 PM
they all shouldnt be firing at the same time
InJ3cted
11-08-2005, 03:51 AM
what ecu are you running? you need to convert to obd1 with a p72 or run a obd0 wiring harness with the resistor pack because the injectors are different between obd1-obd0 diff voltages. if you go obd1 you need the distrib 4 wire o2 and ecu
trazique
11-09-2005, 10:47 AM
Hey! Guess what? its working. OK. The engine is OBD0 (91 B18 ls) the car is OBD1(95 civic hatch) Well it turns out that i was still useing the distributor for the OBD0 on the OBD1 computer. So i got my 92 civic D 15 LX distributor used a set if vice grips and clamped it to the B18 ls and it worked :screwy: So I'm gonna take the gutts out of one of those and put them in the LS distributor housing. Thanks guys.... Trazique
civickiller
11-09-2005, 01:11 PM
see right in my first post, is it converted to obd1.
and you cant swap internals on the dist, you need to buy a obd1 dist
trazique
11-17-2005, 10:39 AM
Ihave an automatic 95 civic hatch and just installed a B18 engine and cable trans (5speed) into it whats the best way to get a clutch pedel into the civic. since they didnt have a cable trans in that model.
