2001 Grand Prix Washer Pump Fuse
knight58
11-04-2005, 03:03 PM
Does anyone know which fuse is used to control the windshield washer pump on a 2001 Pontiac Grand Prix? It is not listed in the manual or in either fuse blocks. My pump is not working and want to start with the fuse as I start trouble shooting.
BNaylor
11-04-2005, 03:34 PM
According to the wiring diagram, there is no fuse. It shares the same 12 volts from the main wiper fuse. From the washer switch to the pump it is a straight shot via wiring. It's either the pump or switch. You can check to see if you have the proper voltage at the pump connector.
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
knight58
11-04-2005, 05:33 PM
Oh well, it was just a thought. With all of the posts about bad pumps, I'm betting pump over switch as the problem. Thanks for the quick reply.
