96 Roadmaster Wagon Auto Leveling System
2k3windstar
11-03-2005, 07:46 PM
My father has a '96 Roadmaster Wagon with the Auto Leveling System. It looks like the compressor is not working anymore. I checked all the fuses. I got under the car and used a jumper at the sensing unit to see if the compressor would operate. I could hear the compressor relay click, but not the compressor.
I'll probably pull the compressor to see if I can repair it, but I don't expect that to work. I'd like to convert it over to a manual inflation system, like after-market air shocks. My father would only need the additional load leveling when carrying a load. He has had air shocks on previous cars and liked them fine. Any suggestions?
Thanks,
Eric
Thanks,
Eric
HotZ28
11-04-2005, 06:21 PM
If your struts are good, and you want to elimate the compressor problem, order Monroe part # AK29. This a kit to install a manual fill setup for the air struts. It will work on original struts as well as Monroe. cost about $5.00 and has everything you need including instructions. Installls in about 30 min. Put 25 lbs. of air in the struts to start and take it for a ride. If you need the rear higher or carry a heavy load you may want a little more. Pull the fuse on the compressor and forget it. I did this on mine and would never go back to the auto leveling system.
Below is just one link where you can get the kit. Do a search for AK29 and it will pop up. Some Monroe dealers keep the kit in stock.
http://www.partsamerica.com/
Auto Parts and Auto Accessories at Advance Auto Parts
