are all intakes created equal?
jimmyv-21
11-01-2005, 06:36 PM
so what makes the k&n air intake system so much better that an intake tube and a k&n filter. the off brand can be purchased for a fraction of the price, and you get the same filter. i am aware of the housing that the k&n system, and the nylon tube- but is it really that much better. if you have installed one or the other, have you noticed a difference.
BNaylor
11-02-2005, 12:30 AM
What specific K&N intake system are you referring to...the AirCharger?
Do you have a GT or GTP?
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
jimmyv-21
11-02-2005, 01:39 PM
here is a link to the one i am talking about- it runs 260.00 how much better is it than one that costs 70.00 on ebay
http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=WB3042&Product_Count=49&Category_Code=GPUNDER
jimmyv-21
11-02-2005, 01:40 PM
got the gt....
BNaylor
11-02-2005, 04:18 PM
Which one on Ebay for $70? Do you have a link to check it out.
Although it probably doesn't justify the cost the K&N Aircharger comes with a real K&N filter not a clone like the other aftermarkets. The cone filter on my Thrasher CAI is actually made by S&B which is a good company.
jimmyv-21
11-02-2005, 05:20 PM
here is the link:
http://cgi.ebay.com/K-N-97-03-Grand-Prix-MONTE-CARLO-Z34-all-V6-AIR-INTAKE_W0QQitemZ8011024513QQcategoryZ38634QQrdZ1QQ cmdZViewItem
as you can see it comes with a genuine k&n
BNaylor
11-02-2005, 06:54 PM
here is the link:
Price looks good but I noticed it had a 6.5" K&N cone filter. I thought the one on the Aircharger was bigger around 9". The name brand aftermarkets CAIs like MSP, Thrasher, etc. have a 9" cone. More square inches of air draw. The other problem with the Ebay offering is no heat shield or insulation but it supposedly has a heat resisting aluminum intake tube.
The K&N Aircharger has a composite molded intake tube non-metallic and the heat shield.
The object is to get cooler air from outside the engine compartment, if possible or minimize it (heat).
IMO it's a good alternative for the cost if you want something to get started right away without having to save up. The K&N is definitely over priced compared to the competing products. But I'd shop around for one that has a bigger filter. Good luck!
