Need Help Fast
kokanee27
10-30-2005, 07:43 PM
hey all, i have a 92 prelude and just recently bought new speakers for it, but they are all 2-way speakers. so when i took off the door panels and the stock front speakers i found that those speakers were connected to the deck with a special connector, unlike the rear speakers. the tweeters are using the "slip on" wires that my new speakers use, so i dont know if i should use these wires to connect my new speakers or what. basically, i need help connecting my 2 way speakers where the stock component speakers were.
i_a_n112784
10-30-2005, 10:39 PM
If its one of those grey/white plugs like i think youre talking about, then they can be poped apart using a small screwdriver, or you can just cut it and crimp on your own terminals. Your choice, but personally, I just take the connector apart, it takes maybe 30 seconds.
kokanee27
10-30-2005, 10:41 PM
thats what i thought of to da after i made that post, but then i thought, will the same two wires that were sending the audio to the componet woofers power the coaxials good??
i_a_n112784
10-30-2005, 11:46 PM
Yep, they will, just keep the colors right from side to side. One wire on both sides will have a stripe in it, like red or yellow, or green etc...make sure that is the positive or negative on both sides, or your bass response wont be good.
kokanee27
10-31-2005, 12:13 AM
HEY thanks alot, got the speakers set up and they spound gret
thanks for all the help
Pavlo
11-01-2005, 07:57 PM
For my infinity s I cut off the connector, striped the wire and on the terminals on the speaker there are little holes, i slid the wires in there and soldered them in there. For me that was the most secure way, as I am against crimps.
My advice to you is to learn how to solder and do everything like it should be done.
