2001 Camry Won't Start
Mitchdiz
10-29-2005, 10:17 AM
My normally reliable 4-cyl Camry turns over and starts, but immediately stalls and dies. If I restart it and immediately give it some gas, it runs fine, but as soon as I take my foot off the gas, it immediately dies again. Almost like the idle is set way too low. Could this be a clogged fuel filter? This came on with no warning.
Joe W
10-29-2005, 10:46 PM
The fuel filter ia an unlikely culprit in this case. Has the check engine light come on? When was the last tune-up?
mcclain296
11-15-2005, 08:13 AM
I am having the same problem with a 97 camry 3.0L. I can not make mine do this all the time. It seems like it only does it when it is warm. Everything seems to be pointing toward the IAC but I tested by jumping the e1 to te1 terminal as stated in the repair manual. The rpm did not go toward 1000rpm in 5 seconds but went down. Then I check the resistance across the ICA but it was in specs. I hate to part swap and this time a new IAC cost $175 smackroos.
mcclain296
11-21-2005, 07:57 AM
Well it seems that the IAC was the problem. I took it off, cleaned it up good using a stiff brush with carb cleaner, and put it back on. The wife is happy now.
AccordCodger
11-21-2005, 06:04 PM
Thanks for the posted solution - very few people bother to do that. Cheers!
