1991 Chevy Calavier - Shuts off at stops and shakes
12field
10-26-2005, 01:31 PM
Can anyone help. Car was working great but heat up alittle, nothing hot, and shuts off at stop signs. thanks
airwave_assassin
10-26-2005, 04:31 PM
fuel pump maybe...or fuel filter
ksparticuspa
11-14-2005, 02:23 PM
My roomates '93 had the same problem, it acted just like stopping a stickshift without pushing in the clutch. That car had a blue plug about halfway down the front of the transmission (for the electronic locking torque convertor) once unplugged the stalling stopped.
12field
11-24-2005, 06:21 PM
No, I replace both and still problems went I accelerate. Any other ideas? Thanks!!
jag0034
11-24-2005, 10:14 PM
I had the same problem, I replaced the MAP sensor and the Throttle position sensor and no more jerky no gos!
ebritt
11-26-2005, 07:40 AM
I had the same problem and after $450 and lots of cussing just junked the car...:disappoin
12field
11-26-2005, 08:22 AM
I may be doing same thing - currently at about $350 and alot of time. Did you unplug the torque converter on your transmission. That was one of the problems but still have the fuel stalling/missing problem. Thanks!
OverAllComa
11-26-2005, 12:15 PM
You people always way over-diagnose the TCC problem. The author of this thread also isn't very clear. While the title says "shuts off" and "shakes" the post only mentions "shutting off." If its shaking at a stop, then you're TCC is fine. If its kicking/bucking and then dying at stops after highway-speed driving, then its your TCC.
Your problem sounds like a simple MAP sensor or a TPS sensor, as someone already mentioned.
12field
11-26-2005, 12:22 PM
Thanks for the reply. Not sure about TCC but when I unplugged it the surging at a stop quit. My problem is not solved yet and TPS and Map sensor have been replaced and I have no check engine light on. Any other suggestions would be appreciated. Thanks again for reply!
nuse900
02-25-2006, 01:32 PM
Check the injectors there probably dirty
