difference between 00 ej25 and 05 ej25???
civickiller2.5
10-26-2005, 11:38 AM
I got an 05 2.5 rs and as you may know the aftermarket barly exists for the 05's. All the big companies (AEM, KN, VIbrant, etc.) have parts, for example a light weight pulley kit, for the 99-01 models but not the 02-06.
WHat is the difference between them(If any)?
I dunno I might be screwed up or somethin.
freakray
10-26-2005, 07:17 PM
2000 2.5RS Engine description:
Engine: Phase II 2.5 L 4 cylinder aluminum alloy 16 valve SOHC boxer engine.
Sequential muliti-port Fuel injection,
Distributorless ignition
Horsepower: 165 @ 5600 pm
Torque: 166 @ 4000 rpm
30,000 mile spark plug replacement
2005 2.5RS Engine description:
2.5L 4 cyl boxer SOHC 16 valve
(same used in all other Subarus except WRX, STi)
Aluminum heads and block
Sequential multi-port fuel injection
compression 10:1
Platinum spark plugs, NGK FR5AP-11, firing order 1-3-2-4
Idle speed Manual 650±100, Auto 700±100
165@5600 rpm Horspeower
166@4000rpm Torque
By description, they're pretty much the same, although I am sure there are minor differences.
2turboimports
10-26-2005, 10:21 PM
like electronic throttle body...maaaaaybe. Who knows.
freakray
10-27-2005, 09:10 AM
Yeah, well, I know I could find out all the differences with a few minutes of research, but I don't really want to since I don't have a 2.5 RS right now.....
But, if knowing the info is available, I also know that if somebody actually wanted the info and wasn't too lazy to search, they could get it too.
2turboimports
10-27-2005, 11:36 AM
oh, i wasnt harping, that was the only thing I could think of that may be different minorly.
civickiller2.5
10-27-2005, 01:40 PM
Yah thanks, Ive just been looking at this underdrive pulley kit form unorthadox and they are saying its applicable for the 99-01 impreza. Ive tried e-mailing the manufactorer but u kno how that goes...
Has anyone tried bolting on a pulley set with this problem?
Does it fit and run right because ive seen studies that it gives 2-3 horse per pound, and its a relativly cheap add-on.
Anyone done this before??????????
