Installing a Hitch
corksnifer
10-25-2005, 08:18 PM
Hello I need help. I just bought a 99 jeep wrangler sahara. I just got a hitch for it. It has the skid plate for the gas tank and transfer case. Do I have to take off the fuel skid plate to get those two top bolts on? Is there any other way? If you have any advise I could sure use it.
Ray H
10-26-2005, 05:45 AM
if you are talking about the bolts on the rear crossmember, you shouldnt need to drop the fuel tank skid. You just need to be tenacious. Its a tight fit so try different approaches. I dont know if you are sticking the bolt in from the rear or front, I would put a flat washer then the nut inside the crossmember. Tape the nut to a wrench, put grease in a socket to hold the nut in place, tack weld the nut to a piece of rod and feed it in there.
